ATC 150ASLT Limited Edition
    Κυκλοφόρησε το νέο ενεργό συστημα ηχείων της ATC 150 ASLT Limited Edition σε ειδική έκδοση για τα 45 χρόνια της εταιρείας.
    New Limited Edition SCM150ASLT LE Active Loudspeaker System
    Limited edition system brings exceptional focus to a 45-year heritage of innovation and precision engineering…
    PR Shot SCM150ASLT LE 2020 1080W
    ATC loudspeaker Technology is proud to announce the availability of the SCM150ASLT, a luxurious marriage of world-class transducer and electronic design engineering, conceived to deliver extraordinary levels of clarity, neutrality, transient response and effortless power delivery.
    The 3-way system comprises flawlessly engineered SCM150ASLT speaker towers incorporating the latest ATC designed and built drive unit technology, combined with an ATC P6 power amplifier. SCM150ASLT drivers including the new 25mm neodymium soft dome SH25-76S super dome tweeter, the 75mm soft dome SM75-150S super dome midrange and the SB75-375SL super linear bass driver are driven directly by the six dedicated channels of the P6 dual-mono, 3-way power amplifier, housed in an elliptical billet aluminium chassis, exquisitely machined and finished to complement the impeccable quality of the cabinets.
    Manufactured to the highest standard by ATC’s own cabinet makers, weighing 116kg and at approximately 1.4m tall, each speaker enclosure is finished in selected European crown-cut walnut veneer with a high-gloss polyester lacquer, and detailed with a stainless steel badge, input panel and bespoke limited edition plinth, PVD treated to create an exclusive nickel-like appearance.
    SCM150ASLT Speaker
    Deploying proprietary drivers throughout, the 3-way system uses ATC’s new SH25-76S tweeter, featuring both upper and lower suspension for greater operational precision and lower distortion; the latest evolution of ATC’s signature soft dome midrange design, the SM75-150S, and the company’s low-distortion SB75-375SL Super Linear bass driver. Combined they deliver a response accuracy of ±2dB between 60Hz-17kHz and ±6dB from 25Hz to 22kHz across a wide horizontal dispersion and at a maximum SPL of 117dB. The rear-mounted input panel features a single LEMO aerospace-grade 10-pin connector.
    P6 Power Amplifier
    The P6 is a high-performance Class AB dual-mono power amplifier designed and built by ATC to provide dedicated amplification and optimally matched active crossovers for the SCM150ASLT. It features a total of 6 channels: 2x (200W LF, 100W MF, 50W HF) for a combined output power of 350W/side. Generating a signal-to-noise ratio of more than 105 decibels its ultra-low noise discrete design, paired with 3-way active crossovers with phase equalisation, offers clear and detailed audio reproduction. On the rear panel, professional L/R XLR inputs (from preamplifier/digital source) are joined by aerospace-grade LEMO multi-pin loudspeaker output connectors. Proprietary speaker cables are included with the system.
    As is customary with ATC products the SCM150ASLT and P6 are covered by a six-year warranty
    Αποκλειστική διάθεση : Audio Soul Ultra - Λήμνου 8 - Δάφνη.
    1  3 Jul 2020
    Ενεργό σύστημα SCM150ASLT από την ATC
    Κυριολεκτικώς, για πολύ λίγους. Η συγκεκριμένη έκδοση του SCM150ASLT είναι διαθέσιμη μόνο σε 22 ζευγάρια και -αν σας ενδιαφέρει- θα πρέπει να βιαστείτε. Το πακέτο είναι εξόχως ενδιαφέρον, καθώς, εκτός από το ίδιο το ηχείο, περιλαμβάνει και έναν ειδικά σχεδιασμένο εξακάναλο P6 οποίος το οδηγεί.
    Το τρίδρομο ηχείο βασίζεται στην γνωστή “κεφαλή” της ATC, με το νέο τουίτερ θόλου της εταιρίας και την τελευταία εκδοχή του κλασικού μιντ θόλου της και περιλαμβάνει ένα 15ιντσο short coil γούφερ για την απόδοση των χαμηλών συχνοτήτων.
    Η καμπίνα έχει ύψος 1,4μ, βάρος 116 κιλά και είναι φινιρισμένη από ευρωπαϊκή καρυδιά, με βάση ειδικά σχεδιασμένη για την συγκεκριμένη έκδοση. Η φόρτιση είναι bass reflex. Σύμφωνα με τα στοιχεία που δίνει η εταιρία, το ηχείο έχει απόκριση 25Hz-22kHz (±6dB) και η καμπύλη έχει αποκλίσεις ±2dB στην περιοχή 60Hz-17kHz, με ”με μεγάλη διασπορά”, όπως αναφέρεται. Η μέγιστη στάθμη είναι 117dB. Η σύνδεση με τον ενισχυτή γίνεται μέσω ενός 10πινου ακροδέκτη LEMO.
    Ο ενισχυτής διαθέτει έξι κανάλια, 2x200W, για τις χαμηλές συχνότητες, 2x100W, για τις μεσαίες και 2x50W για τις υψηλές, συνολικά 350W για κάθε κανάλι, με στάδιο εξόδου σε τάξη ΑΒ. Η εταιρία αναφέρει ότι πρόκειται για μια σχεδίαση με πολύ χαμηλό θόρυβο (105dB) και περιλαμβάνει τα ενεργά φίλτρα για το συγκεκριμένο ηχείο, τα οποία είναι ισοσταθμισμένα ως προς τις φάσεις. Οι δυνατότητες σύνδεσης περιλαμβάνουν εισόδους XLR και έξοδο με ακροδέκτη LEMO, προς τα ηχεία.
    info: Audio Soul Ultra, τηλ.: 210-3839.399, http://www.audiosoulultra.gr/, http://www.south-sounds.com/, http://atcloudspeakers.co.uk/
    2  27 Jul 2020
page generated in 75ms (18 queries, 51ms)
