το θεμα των x-over των ομοκεντρων μοναδων των tannoy εχει λυθει με τον καλυτερο τροπο.
απο τον Pelonis.
υπαρχουν και σε Ελλαδα για ακροαση...
The custom DSP comes fixed, tweaked by Pelonis and his design team for a remarkably flat frequency response, though a 5-band parametric EQ can be accessed via a front panel USB connection on the amp/DSP unit (Windows and Mac Control software versions). Asked about the crossover frequency within the DSP, Chris Pelonis replies, “Part of the magic is the crossover... It’s a multipoint cascading crossover, and the slopes are nontraditional. It all happens between 1k and 4k. That’s all I really want to give up.” The crossover was certainly inaudible to my ears, and invisible on the published frequency response plots.
http://www.prosoundnetwork.com/article/pelonis-signature-series-model-42-studio-monitor-loudspeakers/13371#
και τα Kef Blade πχ παραμορφωση και x-over εχουν στα...
Harmonic Distortion 2nd and 3rd harmonics (90dB/1m):
<0.5% 40Hz - 100kHz
<0.2% 200Hz - 10kHz
Crossover Frequencies 350Hz, 3kHz
