- “ES-LINK3” is Esoteric’s proprietary brand new PCM digital link format enables extremely high definition: 48bit/176.4kHz data transmission.The system also supports “DUAL AES 8Fs” format, which allows 24bit/352.8kHz data transmission.
- The D-02 is implemented with highly advanced patent pending technology: “35bit D/A Processing” algorithm.Digital data processing is done with 35bit basis, which definition is 2048 times higher than 24bit based DAC system.Ultimate high definition digital processing contributes to the D-02’s pure, smooth analog sound quality.
- Direct, pure and precise.22.5792MHz “master clock” is used to link two digital devices to maximize digital signal purity.
- The clock module each unit has, is completely isolated from other digital and analog circuits to keep clock signal as pure as possible.
- The P-02/D-02 system is equipped with i.LINK terminals, and supports SACD multi-channel playback when 3sets of D-02 is connected to the P-02.
