Dear friend.I would like to inform you that i do not speak the English language well.So if you do not understand something ask me...[/QUOTE]
I understand all :)
[QUOTE post="745" user="4"]Lot of ACA members have room treatment. You can search here
linkto find these systems and in the near future lot of other systems will be add in.[/QUOTE]
Now I'm looking at photos in Club Meetings.
BUT
There is always a problem.
We are not master engineers or someone who works in Abbey road studios.Never the less we are not professionals or representatives in hi-fi.We are humans and we love to listen to music.We have our systems in our living rooms.Living room is the place that someone has to live with his family.It is not a studio.It is not possible to have two speakers in the middle of it and jump around to go from kitchen to the rooms.We just have a good stereo system in the living room.
BUT
It is easy for you to see that lot of people invented indresting ways of do room treatment in their living room.You wiil find that Mike has some teddy bears in room corners.Also there are always curtains everywhere in the room.
You will not have the best possible result but you will be near that.
There are also lot of other methods like digital equalizer that someone can do room treatment.[/QUOTE]
Is it better to buy expensive loudspeakers or amp than acoustically adopt separate room?
For me tha answer is obvious, because:
In separate room you can have acoustic panels, diffusers, etc. and don't care about if your wife will like them or not.
Also it's separate room, so the background noise is quieter and you will have wider dynamic range, example:
if you have speakers that can produce 88dB at 1 Wat in distance of 1 meter, then sitting 2 meters from speakers you will have 85dB. Getting more powerfull amp will give:
1Wat - 85dB, 2Wats - 88dB, 4Wats - 91dB, 8Wats - 94dB, 16Wats - 97dB, 32dB - 100dB, 64Wats - 103dB, 128Wats - 106dB,
250Wats - 109dB and 500Wats per channel will give you 112dB
BUT having background noice of 40dB you only hear wat is louder so 112dB - 40dB = 72dB />In separate room the background noice can be much reduced. Having 500W amp you will have 92dB of dynamic range and that is much better. This specially goes to those who like to listen to symphonic orchestra, because it's maximum reaches 130dB
That's only two advantages of separate listening rooms.
Maybe some day I will visit Athens and we could meet.
[QUOTE post="745" user="4"]ALSO
Companies know that.Have you notice that one company has lot of speaker sizes?The base for that is that you have to choose the right room for each one.
One other thing that companies do is voicing.In speaker voicing they put speaker in one room and they try to have the best sound.Believe me...companies know that we do not have an anechoic room...
