to add "bits per sample" column in Foobar:
- go foobar/file/preferences/display/default user interface/playlist view
- go right to the upper window Custom Columns and press Add New
- foobar opens a line we can write
- go left "Name" and we put the name "Bits Per Sample"
- go right "Pattern" and we paste this exactly line :
$if($strcmp(%__encoding%,lossy),%bitrate% kbps mp3,%__bitspersample% bit)
- press Apply
we do the same to add "Sample Rate Column..
Just in the "Name" field we put the name "Sample Rate" and in the "Pattern" we paste this exactly line :
$if($strcmp(%__encoding%,lossy),%samplerate% Hz,%samplerate% Hz)
and apply..
our columns are ready to display the info of every music data playing.. Just mention here that the column "bitrate" that exist reaady in foobar HAS NOT to do with the losless files but with mp3 files, showing the bitrate mp3 encoding!!
of cource we can later add or hide those columns with right click in the columns line/columns..
