The best audio system for 2500 Euro!!!
    Okay gentlemen, this is the time where we get together and listen to the best things out there, but that do not cost a lot of money.
    2500 euro, thats the total of the entire system.
    Mike and I will do the math, but we want to here EVERYONE'S opinion.
    We have work to do and then we can take it to the press!! Or even to the show in December!!!!!
    What do you have to lose, help create high end with your ideas and knowledge.
    1  20 Oct 2011
    Floorstanding Speakers
    Monitor Audio RX6 are the latest model in an outstanding line of floorstanding speakers. Their predecessor, the RS6, had extremely favorable reviews in Stereophile, WhatHi-Fi and from AudioREVIEW users. The RX6 has a 5 of 5 from WhatHi-Fi and made the AudioREVIEW forums drool when the images were released. They are on my list of most recommended speakers for about $1000.
    Specifications
    System Format: 2 1/2 Way
    Frequency Response: 38Hz – 35kHz
    Sensitivity (1W@1M): 90dB
    Nominal Impedance: 6 Ohms
    Recommended Amplifier Requirements (RMS): 40-125W
    Bass Alignment: Dual Chamber, Bass reflex with differential tuning.
    Drive Unit Complement: 1 x 6″ RST® Bass driver.
    1 x 6″ RST® Bass/Mid driver.
    1 x 1″ (25mm) C-CAM® gold dome tweeter
    Other Recommend Floorstanding Speakers – Wharfedale Diamond 9.6, Paradigm Reference Monitor 7, Axiom Millennia M60 Ti, B&W 683, Magnepan Magneplanar MMG
    Monitor Audio Silver RX6
    2  20 Oct 2011
    Start with Speakers
    Speakers are the most important factor in determining the ultimate sound of a stereo system. Speakers should be selected first because they also determine the amount of amplifier power you will need to power the speakers. If you already have speakers you enjoy listening to and they are in good operating condition, consider using them in your new system.
    If not, here are a few suggestions for buying speakers. First, check out your local stereo dealer or electronics store for bargains on demonstration speakers or clearance models. Make sure they are in good condition and come with a factory or dealer backed warranty. Minor scratches can be repaired easily, but damaged speaker cones or cracks in the cabinets might present a bigger problem.
    Next, look on Craigslist.org for a pair of used speakers. Craigslist is like a local classified ad list on the Internet. Sellers post various items for sale, usually with a photo, a price and contact information. The best part about Craigslist is it's local and you can see and hear the speakers before you buy them. I've purchased used speakers on Craigslist with good results. They needed a bit of work on the finish, but they worked well and I got a great deal. Don't be afraid to negotiate a lower price if you think you can get a better deal.
    Another place to look is a local thrift shop. You may find some real bargains. I have a friend who purchased some very valuable electrostatic speakers at a thrift shop for a ridiculously low price because the merchant thought they were room dividers. They needed some reconditioning but he walked away with a real bargain.
    Choose a Receiver or Amplifier
    An important reason for selecting speakers first is you know how much power you will need in an amp or receiver. Some speakers need more power than others to perform well.
    Electronic components last a long time so consider using your existing stereo receiver as long as it matches the power requirements of the speakers.
    Check out Craigslist.org for bargains on a used stereo receiver. Another place to look is ebay.com. Ebay is an auction site where you compete with other buyers before a final price is determined. On ebay.com, you may be buying a receiver from a seller far away, so ask questions of the seller via email before you place a bid.
    Look in the classified ad section of your local newspaper or weekly flyer for deals.
    Check out your local electronics dealer for sale or clearance items. Receiver models change frequently and last year's model my have the features you need most. Make sure it comes with a written warranty.
    Select Source Components
    A stereo system needs a source component, such as a CD, DVD disc player or even a turntable. Disc players are very affordable, as low as $49 or sometimes lower even though they usually have only basic features. All DVD players will play CDs, so you might as well buy a DVD player to play movies as well as music discs.
    Your local dealer, Craigslist.org, ebay.com and the classified ads are all good sources for used stereo components.
    Summary
    As the saying goes, one man's trash is another man's treasure. Buying used speakers and components is a good way to buy a stereo system on a tight budget. You may find some real bargains on high-end components that still work well but have been replaced by the previous owner.
    Suggested Reading
    Beginners Guide to Stereo Systems
    Buying a Stereo - How to Purchase a Stereo System - Stereo System Buying Tips...
    Stereo Systems - Stereo Basics
    More Links
    Glossary of Terms
    Suggested Reading
    How to Select, Install and Get the Best Performance from Stereo Speakers
    Reviews and Profiles of Stereo Receivers
    Best Budget Stereo Speakers Under $500 Per Pair
    Related Articles
    Stereos - Articles
    Best Home Stereo Systems at Every Price Range
    Stereo Systems - Overview of Speakers, Components, Sources and Accessories ...
    Best Stereo Systems - Top Pick Stereo Systems - Best Stereo Component Syste...
    Pioneer Elite X-Z9 Stereo System Review
    3  20 Oct 2011
    This is just for show, it doesn't have to be like this.
    If you have a good speaker or tuner or whatever, try to give us the name and we can search for it, and if you have it then even better, or have heard it, please tell us where so we can hear it also.
    Or it could be a Used system or speaker such as the one below
    http://www.highendshop.gr/Omega-Max-Hemp-Stand-Olive.html
    4  20 Oct 2011
  • LUXILLA
    LUXILLA
    Integrated amp Yamaha AS1000 or the magnificent new Primare i22.
    Cd player Dynavox CD-307 Slot-In.
    5  25 Oct 2011
page generated in 56ms (18 queries, 32ms)
