After an inspiring visit to Phi Audio I decided I wanna try my hand at a set of Voigt Pipes. Jacques from Phi Audio was kind enough to assist with the design after I decided what drivers I wanted to use.
**Driver compliment:**
100mm Visaton full-range drivers
10mm Visaton Polycarb tweeters (I decided to add the tweeters to add sparkle to the speakers repertoire)
16mm MDF was chosen
Panels was cut at a local supply store
I assembled the cabinets at a good friend of mine, who has a workshop equipped with every thinkable tool for the job at hand.
Here's some pics of the build up to now. I am still awaiting the arrival of the drivers.
Sizing up side panels
Fitting baffle
1.8 m tall
Sanding edges
