Hail Voigt!
  • Dewald V
    Dewald V
    After an inspiring visit to Phi Audio I decided I wanna try my hand at a set of Voigt Pipes. Jacques from Phi Audio was kind enough to assist with the design after I decided what drivers I wanted to use.
    **Driver compliment:**
    100mm Visaton full-range drivers
    10mm Visaton Polycarb tweeters (I decided to add the tweeters to add sparkle to the speakers repertoire)
    16mm MDF was chosen
    Panels was cut at a local supply store
    I assembled the cabinets at a good friend of mine, who has a workshop equipped with every thinkable tool for the job at hand.
    Here's some pics of the build up to now. I am still awaiting the arrival of the drivers.
    Sizing up side panels
    Fitting baffle
    1.8 m tall
    Sanding edges
    1  27 Jun 2010
  • Dewald V
    Dewald V
    Both cabs assembled
    Filling up all the brad holes
    Cutting holes for the drivers
    Done for now... next up fitting drivers, testing, painting and the enjoying...!
    2  27 Jun 2010
  • Dewald V
    Dewald V
    3  27 Jun 2010
    Amazing pics Dew....Keep us informed...
    4  27 Jun 2010
    WOW, dude you have left me speechless!
    Real craftmanship!
    Inspired by this I suppose:
    5  27 Jun 2010
  • Dewald V
    Dewald V
    Thank you guys!
    They are going to be painted with automotive enamel in cherry red with the plinths in black...
    6  27 Jun 2010
  • Dewald V
    Dewald V
    In a way yes... more inspiration from here: link
    7  27 Jun 2010
    This is really a very good speaker!!!!are you going to put a fostex speaker inside?
    8  27 Jun 2010
  • Dewald V
    Dewald V
    I am using German Visaton full-range drivers - 4" with a .4" tweeter to add some shimmer to the treble.
    9  28 Jun 2010
    I remember listening to the exact speaker at a high end show here in Athens. The woofer had banana peel material amongst other things. They sounded like heaven with bass on tap!!
    The bass comes from the distance it travels before releasing at the bottom of the speaker. The cost of the speaker 4-5 years ago was 1600 euros, 2100 retail. I almost bought a pair, but didn't because they were too fragile for the db's I listen to.
    The company produces a larger heavier model encrypted with bass passages that go beyond physics.
    10  28 Jun 2010
  • Dewald V
    Dewald V
    They probably used these drivers by Fostex: link
    11  28 Jun 2010
    YES that is it.
    I cannot for reasons beyond me, remember the name of the speaker....but I will NEVER forget its sound.
    12  28 Jun 2010
page 1/7 rows 12/84 first page  previous page  goto page...  next page  last page
page generated in 56ms (19 queries, 22ms)
